broke fuel return housing
Old Aug 8, 2008 | 09:54 PM
pmbmax's Avatar
pmbmax
As it says i changing the failed orings on the hpop (lines to head ) and was trying to get more room for cleaning out the ports for the loctite and when the return line broke loose it really broke. like thrue the threads ,any ideas? I have serched but no luck is this part of the filter are is this a part i can order seperate . All ideas are greatly appreciated. I even thought of doing a return upgrade . The truck has alot of miles on it 310000 I run NMCA and pull my race car all over and i like to be able to get parts a dealers but i am open to any ideas . The truck has 4 inch ss exhaust, DP tunner, Wicked wheel , K&N fipk, Banks 6 gun , crank case breather moved, new injectors, That is it Thanks Phil
Old Aug 8, 2008 | 11:33 PM
rebelchevy02's Avatar
rebelchevy02
Diesel Innovations - Products
Check that link.
He has the replacement end cap for the return, just like you said you broke. only $10 also!
Theres also this option
Old Aug 9, 2008 | 11:30 AM
pmbmax's Avatar
pmbmax
I wish i could keep the factory bypass . does anyone have a brack down of the fuel bowl and filter. I would buy a used one if someone has did the delete. Thanks phil
Old Aug 9, 2008 | 11:48 AM
monsterbaby's Avatar
monsterbaby
If this is the only part you need I have one you can have (but won't be able to get it mailed out until monday)
Old Aug 9, 2008 | 12:19 PM
pmbmax's Avatar
pmbmax
Yes that is it. I will try to pm you.
Old Aug 9, 2008 | 01:07 PM
monsterbaby
sent you a pm back and will drop it in the mail on monday
