Engine Gets Very Hot with A/C on
Old Aug 8, 2008 | 06:26 PM
TonyJestis's Avatar
TonyJestis
I have a1996 Ford Econoline 150 conversion van with dual A/C evaporators. My problem is that when I turn on the A/C, the engine gets very warm, especially climbing hills. With the A/C off the gauge stays in the middle of the range. I check my coolant level and it always between the 'cold' and 'hot' marks on the recovery tank. The radiator itself is always full. I have a 302 in the van. The van has about 180K on it, but the engine was replaced about 40K ago.
Old Aug 9, 2008 | 12:14 AM
Bear River's Avatar
Bear River
Former ******
Try cleaning out the radiator and condensor with a pressure washer. If you get enough bugs or bent over fins, the cooling efficiency will drop. The temperature rise means that the radiator is not handling the extra load, possibly because of airflow or efficiency problems. Flushing the cooling system is also probably a good idea.
Old Aug 9, 2008 | 01:16 PM
Dannym's Avatar
Dannym
Check your fan clutch (google for how to do that). They go out frequently and usually leave the fan spinning really slow even though you can still see it spinning.
Old Aug 9, 2008 | 01:21 PM
rclarke's Avatar
rclarke
Cleaning the radiator with a pressure washer requires a little care, you can damage the fins with the high pressure. A 96 with high mileage may have a plugged radiator. I would consider pulling it and haveing a radiator shop clean it inside and out.
Old Aug 9, 2008 | 02:14 PM
HAB's Avatar
HAB
I second that. Every few years pulling/cleaning/boiling out/roding really makes a BIG difference.
Old Aug 10, 2008 | 07:56 AM
TonyJestis's Avatar
TonyJestis
Thank you, one and all. You have confirmed my previous suspicions and direction of correction.
