Modular V10 (6.8l)
Valve Float??? Towing 5100pds
Old Aug 14, 2008 | 03:46 PM
  #31
bro460's Avatar
bro460
I don't have a vaccum pump for testing. I'll work on trying to find one. But, I did notice that I don't have any vaccum on the EGR vaccum line when I put my thumb over it and apply slight throttle. Should i have a consant vaccum? Or only when the throttle is applied? Can the EGR vaccum regulater be broken or the DPFE sensor screwed up causing no vaccum.
Old Aug 14, 2008 | 03:56 PM
  #32
dkf's Avatar
dkf
It would be nice if you could get a custom tune to delete all the EGR crap and take it off your truck altogether. I never dealt with such a project but have heard it being done a few times on the 6.0l diesel. I'm no fan of EGR, had to do some work recently on an Explorer and the mechanic showed me what to replace as he was having similar problems with his explorer and hasn't sorted it out yet. A DPFE from Ford cost around $150. They tend to clog up over time. Also be careful with the vaccum lines they are brittle plastic. I broke one and used a piece of silicone fuel tubing to fix it.
Old Aug 14, 2008 | 03:57 PM
  #33
krewat's Avatar
krewat
FTE Leadership Emeritus
You should get vacuum when you touch the throttle... part throttle, something. Light-to-medium loads is when the EGR comes on, every other vehicle I've ever played with the EGR on, I've been able to get vacuum at the EGR when I just tap the throttle.
I'd think the DPFE would trigger a CEL if the EGR wasn't coming on, but who the heck knows...
Want a vacuum pump? Stick the end of the hose in your mouth and suck
Old Aug 14, 2008 | 05:31 PM
  #34
Mmaxed's Avatar
Mmaxed
Just don't ask your wife to do it. It ain't pretty. It was kinda fun though.
Old Aug 14, 2008 | 11:10 PM
  #35
krewat's Avatar
krewat
I don't know, my wife, well, she just might
Old Aug 21, 2008 | 01:06 PM
  #36
bro460's Avatar
bro460
Since putting the muffler on it started stalling. After about 4days of driving around with it stalling it seemed to have re-calibrated itself because now it runs and idles really good. Exhaust even sounds better.
Haven't done anything with the EGR valve problem but 80% of the problems are now gone. I think that the muffler was playing a part in all of this afterall, because I now have way more power but it could be better. I'll keep you all posted...
Old Aug 21, 2008 | 01:39 PM
  #37
dkf's Avatar
dkf
Thats weird, I screwed around with exhaust on these trucks a lot with no problems, of course they didn't have EGR. Would be nice to see what your A/F ratio is doing.
Old Aug 21, 2008 | 02:05 PM
  #38
bro460's Avatar
bro460
I have noticed a decline in gas mileage latley and a fuely smell out of the pipe but, not bad. The decline might be the way I'm driving it though, Love the exhaust sound.
Old Feb 19, 2009 | 10:36 AM
  #39
bro460's Avatar
bro460
My problem is over, the ford dealer found #3 and #9 cops failing but not giving a CEL. Truck is running strong now.
Old Feb 19, 2009 | 03:55 PM
  #40
m350's Avatar
m350
Good old Cop's,,,ahh 200 k,,its about time for all of them to be replaced,,Go with MotorCrafts ! Any valve noise now,,,or has this all cleared up now ?
Old Feb 19, 2009 | 05:05 PM
  #41
bro460's Avatar
bro460
It runs perfect now, no valetrain noise anymore. I will see in the spring when I pull out the travel trailer and run a hill.
Old Feb 19, 2009 | 05:36 PM
  #42
V10 Hunter's Avatar
V10 Hunter
Wow all that and it was 2- COP's!! Well with all the parts you replaced you should be good for awhile!~
Old Feb 20, 2009 | 11:54 AM
  #43
bro460's Avatar
bro460
Bad news guys, I still have problems!!!! Definatley improved in the power department but I still have a miss intermittently and last night it stalled out on me 3 times. I will be replacing all the COP's when I can, SOON. And then go from there.... Keep you all posted for sure
Old Feb 20, 2009 | 03:11 PM
  #44
Fordfanatic4life's Avatar
Fordfanatic4life
ur truck just luvs the money ur throwing at it.. is all..
some vehicles are spoiled and just luv having repairs done...haahahah
Old Feb 20, 2009 | 10:41 PM
  #45
ATXZJ's Avatar
ATXZJ
Been there and done that with my 99. The V10 did not start miss-firing until i swapped the plugs and boots. Thought it was a COP, but because it was intermittent, it wouldn't throw a code.
I changed ALL the COPs and boots again and nothing improved. After all was said and done, it was the injector harness.The plugs were not secure at the injector itself and was intermittently losing contact. The problem was created by moving the harness around for the plug change and was exacerbated by years/mileage.
HTH -Marcus
