6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Sputtering
Old Aug 7, 2008 | 07:41 PM
Moyerboy's Avatar
Moyerboy
Question Sputtering
I know there was a post about sputtering but has anyone had the truck sputter when in the throttle heavy at low rpms and once the throttle is relaesed and reapplied the same its gone? along with loads of black smoke when under the sputter. the truck already has a black smoke under a low rpm load but it gets worse when the sputtering starts.
Old Aug 7, 2008 | 10:39 PM
SANDDEMON08's Avatar
SANDDEMON08
Your truck should not blow black smoke if it is stock. The somke would be a DPF problem. What is the build date of your truck?. If its an early job one there were some injectors issues and some chafing issues on some of the wireing harness that caused the issues your having.
Old Aug 8, 2008 | 10:05 AM
Demolition's Avatar
Demolition
Yes. Mine is white smoke, at least until recently when the truck started blowing black smoke all the time. I started keeping a log and mine seemed to occur when I was in the rain, and had stopped at a light and then turned left and accelerated, (Maybe coincidence but there it is).
Had my smoking DPF replaced and it has not done it since in the rain. Either way, get your DPF replaced. Mine runs better now though it seems to go into regen a lot more but for much shorter periods of time.
Old Aug 8, 2008 | 06:37 PM
Moyerboy's Avatar
Moyerboy
my truck is a job 2 if i remeber right and the truck smokes all the time not just in the rain its really bad when its cold ut slowly clears up. I guess ill have to make an appointment at the garage hopefully i can go somewere other than th edeaer i bought it from they ne ver seem to fix the truck just lok at
Meydawg51
22
Aug 30, 2016 03:59 PM
cpye2
Apr 25, 2016 10:56 AM
Restlesswildman
Mar 27, 2016 11:46 AM
GM Woodrow
Jul 28, 2015 08:03 AM
WHT00EX
May 22, 2008 11:23 AM
