need help on mods asap
Old Aug 6, 2008 | 12:17 AM
conman3300's Avatar
conman3300
well im wondering what to do on the foil delete mod and zoodad
for the ic pipe i just take it off nothing else and then work on foil then paint and put back
and for the zoodad i just drill a few holes and done or am i missing something
im sry i no theres a bunch of posts on these mods but i cant seem to get what i need and if yall have any pics i would like to see them thank you all for any help
Old Aug 6, 2008 | 12:21 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
You have the mods down pat. Do what you just said and you will be good to go. I made a square in the plastic for the ZOODAD. Took the foil off and polished the tube for the IC tube.
Easy as pie.
Old Aug 6, 2008 | 12:24 AM
camodown's Avatar
camodown
Look carefully at the IC pipe near the p/s pump. Mine had a hole worn in the pipe
Old Aug 6, 2008 | 12:38 AM
superduty4x4's Avatar
superduty4x4
I've seen a handful of IC pipes that were cracked on the seam under the foil as well.
