Overdrive
Old Aug 5, 2008 | 05:49 PM
fitz888's Avatar
fitz888
Overdrive
By shuting off the overdrive is it like a tow mode/harder shifts,locking up torque converter more or is it simply taking away 4th gear.
Old Aug 5, 2008 | 11:52 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
just takes away 4th gear
after you drive for awhile with a trailer, the tranny will adapt and start to shift different. makes it really weird once you unhook the trailer...the tranny has to relearn a normal shift pattern
Old Aug 6, 2008 | 01:20 AM
deisele75's Avatar
deisele75
It does not take away 4th gear. It just unlocks the torque conveter in overdrive.
If i'm crazy, someone please correct me.
Old Aug 6, 2008 | 01:55 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
try it. from a dead stop accelerate to 50 mph and hold. at 40-43 mph it'll shift into 4th gear. with o/d off, you will remain in 3rd gear. just count the shifts.
the O/D on/off switch does the same thing it has always done since 1992 when the E40D transmission was introduced. it electronically isolates 4th gear from being used.
my Dodge on the other hand does what you are describing. the Tow/Haul mode in my Durango senses shift patterns and will lock out 5th gear and 4th gear if necessary. Supposedly the 09 F-150 will have a similar Tow/Haul setup
Old Aug 6, 2008 | 05:41 PM
Oldguy4's Avatar
Oldguy4
I have to agree with Tylus, Watch the tack and you can see the torque converter lock up. Then push the OD button and it will shift into overdrive.
