Radiator Supports
Old Aug 5, 2008 | 01:13 PM
Blackwaterforge's Avatar
Blackwaterforge
Radiator Supports
The frame on my 66 F250 Camper Special has some rust damage around holes in frame where radiator supports go. Can anyone tell me the diameter of holes,distance between centers and distance to center from the end of the frame? Thank You!
Old Aug 5, 2008 | 09:07 PM
camperspecial65's Avatar
camperspecial65
the bushing on the upper core support bushing has a 7/8" dia. hole as original. The bushing has a part of the it that is wider then the main cushion itself...the overall thickness at the thickest is 15/16"...the thickest parts OD is 1 3/8" which is the portion that rests in the frame hole itself. The upper and lower cab mount bushings are the same as the ones used on the core support. If the cab is off my guess is the front cab mount holes on the frame would be the same. I havent removed a cab in years so I am guessing as I said about the frame hole diameter.
If you want, you can send a pic of what you have and I can give you a hand if you wish.
- cs65
Old Aug 6, 2008 | 07:24 AM
Blackwaterforge
Thank you for your response. Are the holes in frame 15/16 or 1 3/8? I am going to weld up and redrill. I need diameter,distance between centers and distance to center from end of frame.
Thank You!
Old Aug 6, 2008 | 06:43 PM
camperspecial65
It would be 1 3/8". As for the distance center to center, if your core support is good, I would take the measurement from there.
What is the diameter of the holes in the frame as it is now...
- cs65
