Overheating problems
Old Aug 4, 2008 | 07:26 PM
06powerstroke06's Avatar
06powerstroke06
My 07 F-350 was pulling a load and got up to 230 degrees a wile back. the fan never came on. I took it to the dealer and couldnt find anything wrong with it and the fan came on when they drove it. They also unpluged the edge box. I got it back and didnt have any problems till I pulled a load last week and it overheated again. I have it in my shop right now with the radiator and intercooler out of it cleaning them and was woundering if anyone knew what the problem is.
Old Aug 4, 2008 | 07:42 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
What size load was it? Was it on the flats or 6% grade for miles? We need more details on the pull in order to help.
Old Aug 4, 2008 | 07:47 PM
06powerstroke06
it was a 25' stocker with 5 horses in it. It was on flat grade, Nothing it hasnt done befor with out any problems.
Old Aug 4, 2008 | 07:59 PM
bigredtruckmi
Veteran: Navy
Did you do anything different with the edge box? turn up the power etc.
Old Aug 4, 2008 | 08:03 PM
06powerstroke06
no i run it on the tow mode when pulling. I think it is a problem becouse my 06's fan comes on at 206 and the fan never came on at all and i had to stop and un hook the 07 becouse it was at 230 and never came on. i had to get the old 94 7.3 to pull it.
Old Aug 5, 2008 | 12:49 AM
bismic's Avatar
bismic
The fan on our 6.0L does not come on at one specific temperature - so I learned not long ago (thanks PowerstrokeHD).
FYI:
Engine temperature is not the only parameter that the PCM monitors to determine cooling fan operation. This is the reason that you will see some variation in engine temperature as it correlates to fan operation. The operation/description of the FSS (Fan Speed Sensor) from the PC/ED manual has a fairly good explanation as to how the system "thinks". This is not your traditional engine hits temp X and the fan clutch locks up. The fan speed sensor is a Hall-Effect sensor integral to the vistronic drive fan (VDF). The powertrain control module (PCM) will monitor the sensor input and control the VDF speed based upon engine coolant temperature (ECT), transmission fluid temperature (TFT) and intake air temperature (IAT) requirements. When an increase in fan speed for vehicle cooling is requested, the PCM will monitor the FSS signal and output the required pulse width modulated (PWM) signal to a fluid port valve within the VDF.
Old Aug 5, 2008 | 12:56 AM
bismic's Avatar
bismic
FYI - the engine is suppose to defuel at 227 degrees - so apparently the PCM did not think you hit 227. I assume the 230 value you quoted was with aftermarket gauges? If so, folks here with experience say they measure higher than the OBD-II readings: 10-20 degrees higher in many cases.
You say your truck overheated, but was it just the gauge reading or were there other signs (like puking coolant)? If it was just the gauge - what was the highest you had seen previously?
Old Aug 5, 2008 | 09:30 AM
06powerstroke06
It was on the edge gauge. i beleve the highest it got to was 235 (it would of started puking coolant if i keep pulling im sure) and it never got higher than 209 befor this happend.
Old Aug 5, 2008 | 11:02 AM
jmaskew's Avatar
jmaskew
I have aftermarket gauges, when towing our 20' Travel Trailer a couple of weeks ago the fan would come on when going up hill. It didn't roar like an airplane but I could barely hear it. If I put my foot down a little more the fan speed would start to increase. The temps when the fan first came on were: ECT= 212, EOT 220-223, Transmission 190. When the ECT would hit 218 I could really hear the fan but it still wasn't roaring. ECT never went above 218 and EOT never went above 230, transmission didn't go above 200. The ambient temp was around 112 degrees. On the flat parts of the highway ECT=210, EOT=220 and Transmision Temp 185. Sorry for the long post but I just wanted to throw some temps out that I experienced, hope it helps.
Old Aug 5, 2008 | 11:36 AM
06powerstroke06
The fan never came on I got out with the hood up and reved the motor and it wasnt on.
Old Aug 7, 2008 | 07:21 AM
06powerstroke06
I figured it out. It was the edge box. Now i have to see if edge will give me a new one. again...
