2004 4X4 V10 73K Excursion
Old Aug 4, 2008 | 06:58 PM
OnlyFords4Me's Avatar
OnlyFords4Me
I'm thinking of buying the X mentioned in the title. What are some known issues or problems that I should look for? Thanks in advance.
Old Aug 5, 2008 | 08:05 AM
6686L's Avatar
6686L
1) LOOK at and SMELL the engine and transmission oil dip-sticks. Walk away if they suggest poor maintainence
2) Same for rear axle. Many people, like myself, bought the EX to tow our boats. Ever seen how deep into the water some people back their boat towing vehicles ? Putting a surface vehicle into water above the bottoms of the rear axle seals is a guarantee of VERY expensive repairs. "Milky" differential oil is a sign that you need to walk away fast from that vehicle - obviously, if the owner is that much of a clown, pretty good chance he's screwed up other aspects of that vehicle too.
Old Aug 5, 2008 | 09:24 AM
Fosters's Avatar
Fosters
How exactly do you plan on smelling the rear axle dipstick?
Old Aug 5, 2008 | 10:45 AM
6686L's Avatar
6686L
Good point - my apologies for not explaining this to those of you who are not mechanically inclined.
A competent "pre-buy" vehicle inspection should include an inspection of all the vehicle's major fluids. A lot can be learned from this. As Foster notes, I should have pointed out the specifics of how you check front (if four wheel drive) and rear differential fluids for signs of contamination. (as a side-note, it infuriates me that the industry is so cheap these days, they dont put drain plugs on the bottom of the axle - to drain them, you have to pull the covers.)
In any event, the "add fluid" plugs have an indentation in which you place a 3/8 sized ratchet wrench. You un-screw the plug, and simply look at the inside. Fluid should NOT show any "milky" bubbles (indicating water contamination).
Old Aug 5, 2008 | 09:10 PM
Yesprofit's Avatar
Yesprofit
Also, this may sound simple, and nothing to do with mechanical issues, but I would climb up and take a good look at the top of it. If it was a rental, or someone did not know the size of the garage/carport, you may have some damage up there. Good luck, I absolutely love mine, and you are at a terrific site for information.
