Power window problem
Old Jul 28, 2002 | 01:20 PM
theologian's Avatar
theologian
My driver's side rear door window no longer operates. How do I fix this problem? as far as I can tell the switch still works
Wm
'96 F450 White with Grey interior Crew Cab. Banks Turbo, Intercooler and Exhaust,
Power pack Chip, shift kit, Auxiliary transmission, electronic enhanced transmission control,
16 forward and 4 reverse ratios. 340hp 660ft lb 4 wheel drive, 4.10 gears, 12,ooo# winch
Old Jul 28, 2002 | 01:50 PM
Jimbare's Avatar
Jimbare
all alone in the world
window motor probably bad. just replace it, should take care of it.
Old Jul 28, 2002 | 03:11 PM
fatfenders's Avatar
fatfenders
If you have absolutely no response from the window motors, check for 12V and good ground at the motor when you get the door panel off. PW switches and relays are high fail items. Motors tend to warn you they are going out with slow performance.
Dewayne
Old Jul 28, 2002 | 06:55 PM
kioolt's Avatar
kioolt
[updated:LAST EDITED ON 28-Jul-02 AT 07:56 PM (EST)]Power window motors and door locks on most Fords do not use the motor ground to operate. They use a reversing polarity arrangement to operate. One polarity on the two wires on the motor will make it go one direction and by changing the polarity the motor will go the other direction. In other words the motor will still run if you unbolt it from the door and have no ground. Therefore a ground is not important for operation.
Old Jul 28, 2002 | 10:49 PM
theologian's Avatar
theologian
OK, I took off the door panel. I looked around and could not figure how to get at the motor, any ideas..?
Wm
Old Jul 28, 2002 | 11:09 PM
Jimbare's Avatar
Jimbare
if you look at the door with the panel off, around where the motor is you will see 3 little indintations. if you feel around the head on the motor you can feel the heads of the bolts that hold it in. the little indintations should line up with the bolts. drill holes on these spots, i think 3/8, then a 5/16- 1/4 drive socket or a nut driver will fit in and you can get the bolts out. put a wedge in beside the window so it doesnt fall on your arm while you are working on it. soon as you do one, you will be an expert at it.
Old Jul 29, 2002 | 08:21 AM
fatfenders's Avatar
fatfenders
Kioolt
You are correct. Even alot of the aftermarket PW kits work as you describe. My advice was generic in nature. I have seen so many components replaced without diagnosis and the problem turns out to be a bad ground, switch etc. Sorry if I caused confusion.
Dewayne
Old Jul 29, 2002 | 11:09 PM
theologian's Avatar
theologian
looks like I am going to have some fun fixing this problem. I have to wait until the weekend to get to it, but will try that, and if I need more, I will post.. Thanks.
Wm
Old Jul 31, 2002 | 12:27 AM
merc460's Avatar
merc460
