Sponsored by: Auxito
4x4 Problems
Old Aug 4, 2008 | 03:26 AM
bamafordguy97's Avatar
bamafordguy97
4x4 Problems
This is a simple Question I think.
I think my 4x4 system blew a fuse or something. It was working one minute and I put it back in 2high drove to the store and come back. Went to put it back in 4 low and nothing happened. My personal opinion is it is either a bad dash switch or a blown relay/fuse or something of the sort. Question is. Where is the fuse and or relay for the 4x4 on these trucks. My owners manual that has those little diagrams that tells you what number slot does what came up missing LOL. I feel blind without it sometime.
Thanks for the Help Guys
1997 Ford F150 Ext Cab 4.6l
Lariat
246,000 Miles and still running strong.
Old Aug 5, 2008 | 09:14 AM
jleo's Avatar
jleo
Position 23 (10 amps) of the fuses under your steering wheel is the 4wd clutch relay, electronic flasher, 4wd/2wd vacuum soleniods and trailer tow battery charge relay.
Position 17 (30 amp) of the fuses under your hood is the 4wd transfer case shift motor and clutch
Hope this helps.
My F150 has the same problem and both of those fuses are good so I dont know whats wrong.
Old Aug 6, 2008 | 12:18 AM
bamafordguy97
Its either that or the ****/Switch that is on the dash that is bad. Im hoping and praying anyway. Those 4x4 Motors that bolt up on the underside dont sound like there going to be cheap. IF however I come across anything else I will let you know!
