Sponsored by: Real Truck
wanting a dually
Old Aug 4, 2008 | 12:41 AM
roube's Avatar
roube
wanting a dually
I have a 99f3504x4 single wheel, Iam wanting to convert to a dually. I think I just need to change the hubs.not sure about axle width anybody got any ideas
Old Aug 4, 2008 | 09:26 AM
redford's Avatar
redford
FTE Leadership Emeritus
Are you just wanting a dually look or are you hoping for the extra hauling and towing capacity?
Old Aug 4, 2008 | 01:01 PM
Vijay's Avatar
Vijay
The axle is different on DRW versus SRW!!!so, if you are looking at increased load capacity I think that is pretty much out in drain.
Old Aug 4, 2008 | 05:16 PM
roube's Avatar
roube
in which way are they different width,size or just hubs I'm even considering changing axles. the loads I pull vary anywhere from 6 to 15000lbs
Old Aug 4, 2008 | 05:36 PM
krewat's Avatar
krewat
The DRW is a Dana 80, rated at a higher payload than the Sterling 10.5".
Best way to figure it all out is go to a junkyard with a DRW and bring a tape measure
Old Aug 4, 2008 | 08:02 PM
Vijay's Avatar
Vijay
Also, since used truck sales (price wise) has been heading south in recent past; I suggest you look for a used DRW truck instead, if that is an option. Making too much mods to increase the towing capacity is two edged knife. The decision is yours but if you end up moding your existing truck, start at your local salvage yard. The springs on DRW are rated different compared SRW. Usually DRW are 4:10 gears std, so, you will end up changing gears in the front diff too(it's 4x4!!!). You will need a bed too, used ones(take offs) are like $700-1000 on Ebay.
