Sponsored by: Real Truck
Anyone having problems with their heating/cooling system?
Old Aug 3, 2008 | 03:57 PM
06 F350 Crew's Avatar
06 F350 Crew
I have an '06 350 6.0L. Yesterday I noticed that my fan is "stuck" on high while the truck is running. It doesn't matter which outlet it is directed through (floor/dash/defroster) or even whether or not the heater/AC is on. I checked the fuse and it is fine. If I remove it, it does turn the fan off. Couldn't find any mention of this problem by searching. Anyone have any ideas. Any help would be appreciated.
Old Aug 3, 2008 | 06:30 PM
ReAX's Avatar
ReAX
For the fan to be on high when the key is on, there is a short supplying switched power to the fan motor. If your truck is stock and no one's fooled around near the fan, I'd suspect your a/c fan switch is fragged.
Old Aug 3, 2008 | 07:24 PM
dchamberlain's Avatar
dchamberlain
Check the blower fan relay in the Central Junction Box. For the 2004 it is relay 301. Looking at the wiring diagrams, it doesn't seem likely, but the 2006 might be a bit different.
