Sponsored by: Real Truck
Front brakes
Old Aug 3, 2008 | 08:41 AM
Matt400's Avatar
Matt400
Front brakes
Ok yes I may be stupid,,I changed my front brake pads yesterday,,,but the truck is still making the same sound up front,,,you can here rubbing when brakes are applied,,,truck has 56,000 on it,,,,I'm assumming the rotors need to be turned or at this point should I just replace??
I get no shutter or feeling of warped rotors at all
Thanks
Old Aug 3, 2008 | 10:05 AM
99f350sd's Avatar
99f350sd
You may have bad bearings. main bearing or needle bearing . Are the axles spinning? Are the rotors smooth? Look on the back! I've seen pretty messed up rotor's never make a noise...
Dick
