rocker arms
Old Aug 2, 2008 | 12:11 PM
lucky no. 7's Avatar
lucky no. 7
rocker arms
would a set of 302 pedestal mount rockers work on our motors? i know the small blocks use a channel made of tin to hold the rockers straight but our heads have those nice little cast in ''guides'' to hold the stamped rockers straight on their pedestals, i'm talkin about trying to use a set of 1.72 302 roller rockers that are bolt down
Old Aug 2, 2008 | 04:56 PM
80broncoman's Avatar
80broncoman
No the rocker for a 302 is much shorter from the fulrum to the valve roller.
If you find set for a 429-460 they are eaxtly the same as the 351C,351M/400 bolt down rockers.
Here is a set for $229.99 (+ $10.00 shipping):
eBay Motors: Ford 351C 460 Scorpion roller rockers PEDESTAL MOUNT (item 200238579212 end time Aug-11-08 09:04:29 PDT)
Old Aug 2, 2008 | 05:59 PM
TMI's Avatar
TMI
We also carry those rocker arm for $225 a set
Old Aug 2, 2008 | 07:36 PM
80broncoman
Opps sorry about that. I keep forgeting you have so many more more parts than you used to.
Old Aug 2, 2008 | 09:57 PM
lucky no. 7
only thing is that they still arent adjustable basically you just get the benefits of friction or lack there of, think i'll just save up and get the conversion kit and a set of regular stud mounted rockers
Old Aug 3, 2008 | 12:41 AM
80broncoman
You most likely don't need an adjustable rocker. And if your running a hyd cam there will no benifit to adjustable rockers.
