High Speed Miss
Old Aug 28, 2002 | 08:36 PM
nocash's Avatar
nocash
High Speed Miss
I have a 87 F-250 2wd 7.5l ( opec special ) and am getting a miss at high speeds. Starts at 50mph. Also when the truck ran well the oil pressure read low. Now when the miss started the oil pressure returned to normal. Some history: Truck ran like crap replaced carb. still ran crappy.Then wouldn't start at all. I found yellow wire from starter sol. corroded at splice on drivers side inner fender. Fixed that and truck started fine. I changed plugs and they looked fine. It starts good and runs great in town but out on the highway miss developes. Do I have 2 problems or do they coincide. TIA Wayne
Old Aug 30, 2002 | 10:45 AM
MrBSS's Avatar
MrBSS
High Speed Miss
Old Aug 30, 2002 | 03:12 PM
gasman6674's Avatar
gasman6674
High Speed Miss
Check your cap, rotor, wires and coil output. You could have a cap thats cracked or carbon tracked, cracked or tracked rotor etc.
Eliminated the obivous in the secondary ignition then check or change the coil (they are fairly cheap)
Hope this helps
Regards
Gasman
Old Aug 30, 2002 | 10:26 PM
nocash's Avatar
nocash
High Speed Miss
Thanks Gasman Will check it out.
DaveO1990
Apr 8, 2013 07:25 AM
rblaine9000
17
Aug 30, 2010 05:32 AM
Flyin5
39
Dec 13, 2009 02:46 AM
rlmtowing
Feb 16, 2009 09:35 PM
