axel problem!!!
Old Jul 31, 2008 | 07:14 PM
bigstef's Avatar
bigstef
axel problem!!!
this is my probleme..i got a f-250 1984 6.9diesel with a twin hight beam axel.i want to chang it for a straith axel of a f250 2001 can it be fix easely or wth some adjustement. i can have the axel complite for 300$
Old Jul 31, 2008 | 07:57 PM
axe_handle's Avatar
axe_handle
The 1999+ Super Duty trucks used a different bolt pattern, so you will either have to change the rear too and run 8 x 170 mm wheels, find a way to change the front hubs to 8 x 6.5", or run different wheels on the front and back.
Old Jul 31, 2008 | 08:03 PM
bigstef's Avatar
bigstef
thanks man
Old Jul 31, 2008 | 08:07 PM
bigstef's Avatar
bigstef
so can some one tell me if and where i can find a front axel who can fit on my truck..i buy one but i need the disck..bering ..hub...galipper..trak bar drag linkk and here it cost $$$$ so can you tell me the best place to buy on the net
Old Jul 31, 2008 | 08:08 PM
bigstef's Avatar
bigstef
i forget to tell you i live in qubec city...the cost for all i need is2000$
Old Aug 1, 2008 | 12:40 AM
ford trans tech's Avatar
ford trans tech
you need to find the brackets and frame mounting parts from another truck no later than a 1997 model
Old Aug 1, 2008 | 03:10 AM
Dodge/Cummins's Avatar
Dodge/Cummins
That axle is probably a Dana 50 too which is kind of an odd-ball and not as strong as the Dana 60 ford trans tech recommends.
You might find a whole truck cheaper than just the axle's cost alone.
Ford front Dana 60s are VERY desireable as they are high-pinion and until '91-'92 king pin style. I ussually see them for sale for around 1200-1800 bucks alone.
Watch out for early '80s F-350s as they might/probably have the TTB you already have.
Don't get one out of a GM/Dodge/International as they are right-side (passenger) diffs. Dodge switched to a left side diff. in '94 but it is a unit-bearing style and has no manual hubs, as well as being a coil sping/control arm suspension.
I have quite a few times bought a whole truck, swapped the axle(s) between the two and then sold the truck again for the same price or more (if I fixed the other truck up some). This method equals free axle(s).
Ness57
Jul 14, 2013 10:39 PM
Feardeere7
Jan 22, 2013 07:11 AM
weswes01
Offroad & 4x4
Apr 17, 2006 05:49 PM
sed8ed
Sep 18, 2002 11:23 PM
