gas gauge
Old Sep 9, 2002 | 07:26 PM
crewcab77's Avatar
crewcab77
gas gauge
I'm putting a second gas tank on my 77 ford truck. I'm wondering how i can hook up the gas gauge so it works on both tanks?
Old Sep 9, 2002 | 07:28 PM
Mil1ion's Avatar
Mil1ion
gas gauge
If the tanks were joined with a cross pipe > That way you would be monitoring the whole fuel system at once.
[font color=red]Dennis
FTE Assistant Administrator
[/font]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
Old Sep 9, 2002 | 11:10 PM
Mike W's Avatar
Mike W
gas gauge
Or, if you have a valve to switch between tanks, then use a toggle switch to switch the two fuel tank senders to the gauge.
Old Sep 10, 2002 | 04:32 AM
crewcab77's Avatar
crewcab77
gas gauge
would i have to use a 3way toggle switch?
Old Sep 10, 2002 | 11:39 AM
Mil1ion's Avatar
Mil1ion
gas gauge
The original post said ONE sending unit to monitor BOTH tanks.
Not like FORD already works.
Again to use ONE sending unit to monitor BOTH Tanks,you would need to TWO cross pipes welded laterally between the two tanks > One on the TOP & one on the BOTTOM thus turning it into one tank with double the capacity.
Why you would want to do this I don't know.
I've had a bad sending unit in one tank for 10 years.
You just learn to put gas in and drive accordingly.
[/font]
Old Sep 10, 2002 | 07:06 PM
crewcab77's Avatar
crewcab77
gas gauge
I'm not looking to run both tanks at one time. I just want a way to hook up the gas gauge that when i flip the switch from tank to tank that i can use the gas gauge. I would never run the two together that would be dumb.
Old Sep 10, 2002 | 07:33 PM
Mil1ion's Avatar
Mil1ion
gas gauge
Okay you didn't mention you wanted to switch them you just said you wanted use the gauge for both.
I assumed you were already aware that Ford ALREADY uses a Tank switching control that allows the fuel gauge to monitor both tanks.
If you only had one tank that would mean you want to make your truck just like a truck that came with TWO tanks.
You will need a fuel tank,wiring,sending units,dash switch,electrical controller.
[/font]
Old Sep 10, 2002 | 10:06 PM
Mike W's Avatar
Mike W
gas gauge
Use a single pole, double throw toggle switch. Put the gauge wire on the center terminal. One sender to one of the other terminals. The other sender to the remaining terminal.
Old Sep 11, 2002 | 04:27 AM
crewcab77's Avatar
crewcab77
gas gauge
cool thanks alot mike. I thought i could do that but wasn't sure. Thanks again.
Old Sep 11, 2002 | 05:20 PM
Mil1ion's Avatar
Mil1ion
gas gauge
