Coil voltage?
Old May 29, 2002 | 03:47 PM
jtrbovich2002's Avatar
jtrbovich2002
Coil voltage?
Old Sep 10, 2002 | 03:11 PM
a63unibody's Avatar
a63unibody
Coil voltage?
I just installed a Mallory Promaster coil on my 390, the book recommends 4.6-6.9 volts with the key in the ON position, I have 4.6 with my stock wiring, when I put the resistor on that comes with the Mallory coil it drops down to 2.5 volts. Is this enough to run the engine or should I leave off the resistor? Thanks
Robert
Old Sep 10, 2002 | 09:58 PM
Mike W's Avatar
Mike W
Coil voltage?
That is too low. Did you bypass the stock resistor? If you have both in series, that would drop the voltage a lot.
Old Sep 11, 2002 | 12:36 AM
krazdndenver's Avatar
krazdndenver
Coil voltage?
Sounds to me you still have old resistor in line. If your voltage is good without the new one then save it for when the old one goes bed.
Robert
Old Sep 11, 2002 | 08:49 AM
a63unibody's Avatar
a63unibody
Coil voltage?
Thats what I thought! But the instructions that come with the coil say to leave the orginal wiring and resistor wiring in place. Doesn't make sense. I've contacted Mallory and am waiting for one of their tech people to reply.
Robert
Old Sep 11, 2002 | 08:36 PM
Mike W's Avatar
Mike W
Coil voltage?
Let us know what thay have to say. I would like to know if the new coil draws more current then the stock one. I don't worry about current thru the points since I installed my MSD. The points are just a trigger, and the coil is a step up transformer. Leaving the stock ballast in just does not compute to me.
