no headlights
Old Sep 6, 2002 | 08:42 AM
RSANCHEZ's Avatar
RSANCHEZ
Post no headlights
looking for help with headlights for 1998 f150 they dont come on have to play with turn signal handle to get them to come on but they dont always stay on. when i do have them on and i try to use the turn signal the shut off. even when tring to use high beam there is still no lights on. need to know what kind of wiring there is in the turn signal handle wipers work from the handle ok. need help rsanchez
Old Sep 6, 2002 | 09:40 AM
doodaa's Avatar
doodaa
no headlights
Didn't I read somewhere around here there's a connector in the tilt columns that comes loose? Do you have a tilt column? I found corrosion in the switch on my '95, may or may not be a factor on one so new as yours.... just a couple suggestions.
Old Sep 19, 2002 | 08:13 PM
41Clay's Avatar
41Clay
no headlights
Old Sep 23, 2002 | 05:52 PM
yonkers733's Avatar
yonkers733
no headlights
I have a '96 Explorer and one day the headlights just would not work. The had flickered once or twice, but then the just cut out and would not go on at all. The only way I could get the bulbs to light was to hold down (UP) the quick flash. I changed the headlight switch but it didn't help. I finally changed the multipurpose switch on the steering column. That was the culprit. Everything was fine after that.
Tony
