A/C Refrigerant venting!
Today the same thing, I was driving & I heard the same high pressure venting sound, opened the door & smelled refrigerant again. Once again the a/C is still working. I am guessing that there is a high pressure relief valve on the compressor??
This is my wifes truck & I don't drive it often, I am thinking that either the fan clutch isn't working enough causing the higher pressures in the A/C system or maybe it's overcharged. I put gauges on it & it seems to be OK. It's also 110 degrees here!
Any ideas??? Thanks.
If yours has been venting, it won't work much longer....
Yes, a weak fan clutch can cause this as can a high side restriction. The only way an overcharge could explain it is if someone added refrigerant and overfilled it, but you didn't indicate an such work.
Steve
I did add about 10oz of refrigerant, however this was at the beginning of the summer & it needed it since the system was low. I used gauges, thermometer, etc. This was months ago & the A/C issue just recently started so I can rule out it being overcharged. I have charged several A/C systems & I have an A/C automotive certification. This doesn't mean that I know everything though, There is always more to learn I am sure. Just trying to make the point that I wouldn't overcharge it.
I need to pay attention to the fan clutch next time i drive it. I remember that it really used to pull air, You could hear it, very loud on a hot day. I will need to see if it's still the same. My wife doesn't pay attention to stuff like that! Just the stereo, LOL.
Thanks for the info guys! I will let you know what I find out.
Are you sure it cools o.k.? If the fan winds up being o.k., I'd look for a problem or restriction allowing the high side pressure to jump.
Each time that it has vented through the relief valve it has been just after a hot start up. It may have been sitting for a hour or so max. I have noticed that the fan clutch doesn't seem to pull a lot of air upon start up. It starts working once you get down the road & the heat from the radiator hits the clutch.
I checked the condensor & it's free of any external blockage (airflow) When the gauges are hooked up, yes the high side is up there at first however once the system settles & the airflow starts pulling over the condensor then the pressures are within normal range. I am really thinking that this is due to a lack of airflow upon start up & shortly after. Could the fan clutch just be slow to engage or lazy? Or would it be all or nothing? I really don't wanna replace it if it's good. I have never liked fan clutches, I would prefer a flex fan or an electric fan, but it's what it has so it must be able to get the job done.
One last thing, The A/C does cool but I have never thought it was anything to be excited about untill you are on the highway. In town it works just OK. I understand that it's a large area to cool & the rear air drawing off of the same compressor has to be hard on it & not terribly effiecient. Plus it's 110+ degrees in the shade here in Vegas!
Thanks, Rich
BTW Rich, does the vehicle have the factory fan shroud? Is the vehicle running cool? I would check just in case. You may have a heat transfer thing going on.
Could that noise be the expansion valve operating?
It uses an orifice tube. it causes the liquid refrigerant to turn back into a gas. It doesn't use a temperature sensor to operate. just flashes the refrigerant as it passes through it.
My radiator started leaking a bit from one of the plastic end tanks so I just decided to replace it. When I pulled the old radiator out about 20 -25% of it was blocked due to road debris & oily residue. The condensor wasn't though? Go figure. Anyways I'm sure that even though the condensor is in front of the radiator it still probally restricted some airflow. I made sure to spray the condensor out really well too. I think this could have been part of the problem.
