maf conversion help
Old Jul 28, 2008 | 09:43 PM
kjacobs6`'s Avatar
kjacobs6`
maf conversion help
I have a 1992 f150 5.0 i am doing the maf conversion to. I am putting in the a9p computer out of a '90 mustang. According to the wiring diagram in the haynes manual for the truck, pin 8 on the computer goes to the fuel pump relay and fuel inertia shut off. In the mustang wiring diagram it doesnt show a pin 8 or a fuel inertia shut off. What do i do with this pin?
Old Jul 28, 2008 | 11:05 PM
Franklin2's Avatar
Franklin2
Is this any help?
Ford Fuel Injection OBD-II E4OD Mass Air conversion
Old Jul 29, 2008 | 04:52 AM
EPNCSU2006's Avatar
EPNCSU2006
Pin 8 is the fuel pump monitor, which the computer uses to determine if the fuel pump relay is working. If it is not connected, you will get a constant fuel pump secondary circuit failure code, but the engine should still run. The A9P should also have this FPM pin, from the one place I looked online, it looks like pin 19, so you can just move the wire in the connector. The relay is activated with pin 22 on both computers.
Old Jul 29, 2008 | 11:21 AM
kjacobs6`'s Avatar
kjacobs6`
thanks for the fast reply. Thats the one i was leaning towards but wasnt for sure. Hopefully i can get this thing up and running soon. thanks again
