Pcm Code Location
Old Jul 28, 2008 | 09:15 PM
Firefighter 1406's Avatar
Firefighter 1406
Pcm Code Location
I am trying to find out where the code on my pcm is located. Is it located on the door jamb or do I have to pull the pcm or what?
Old Jul 28, 2008 | 09:17 PM
DCSpecial's Avatar
DCSpecial
You should have a sticker on the inside of the driver's door by the hinges (by the fender)......or at least you would have had a sticker there with the code at some point in time.
Old Jul 28, 2008 | 09:37 PM
Firefighter 1406
I have a sticker on the latch side that says calibration 9DTA-AJ.
Then in small letters F8AE-6E061-large CJP. Could that be it?
Old Jul 28, 2008 | 09:45 PM
Ponyboychris's Avatar
Ponyboychris
FWIW, I had no sticker, so needed to pull the PCM.
Old Jul 28, 2008 | 11:13 PM
superduty4x4's Avatar
superduty4x4
I've heard with a mirror you can see the sticker on the side of the PCM but it would be a real PITA to do. I've never heard of a sticker on the door jamb, I'll have to look next time I'm out.
Old Jul 28, 2008 | 11:18 PM
superduty4x4
All the ones I've seen are 3 letters and a number, like PMT2 or VCQ4.
Old Jul 28, 2008 | 11:32 PM
PaysonPSD's Avatar
PaysonPSD
To find your PCM code, you can either remove the case from the back of the PCM and look at the code or you can take a small mirror and check the sticker on the connector. The connector is located on the firewall directly below the master cylinder about 2 inches from the driver's fender. On the side of the connector facing the fender is a sticker with the part number and Catch (Box) Code. Depending on the year of the truck you will find something like XLE4, PMT2, NVK3... always 3 letters & 1 number.
This is an instruction I found on an old post and I was able to read the code on the connector using a flashlight and a mirror. PITA but it worked.
Old Jul 29, 2008 | 02:06 AM
Tenn01PSD350's Avatar
Tenn01PSD350
Well, Jody can tell you what PCM code you have just from the VIN from what I hear. The ones I am familiar with are PMT 1 and 2 and NVK4. Again, call DP, or pull the PCM out. It will be clearly labeled. Probably quicker than calling.
Old Jul 29, 2008 | 03:49 AM
ron's power stroke's Avatar
ron's power stroke
the vin will work as long as the PCM has never been changed..
a pic is worth 1000 word's
http://www.dp-tuner.com/documentatio...PCM%20Code.pdf
if you need to pull the PCM..
http://www.dp-tuner.com/documentatio...STALLATION.pdf
Old Jul 29, 2008 | 09:22 AM
superduty4x4
But can you pull the case without pulling the PCM?
Old Jul 29, 2008 | 09:36 AM
Ponyboychris
I don't think so. It's really not hard to pull the PCM. Just keep your keys in your pocket or on the workbench. No need to unhook the batteries either. 10 minutes and it's out. You need the 10mm deep socket, 1/4" drive and some patience. Once you pull it, you see it not that tough of a job.
Old Jul 29, 2008 | 06:08 PM
superduty4x4
I know how easy it is, did it on Sunday. The hardest part was getting the 10mm bolt out of the wire harness. My early 99 is now run by an 01 PMT2 PCM (soooooo much better).
Old Jul 29, 2008 | 06:54 PM
PaysonPSD's Avatar
PaysonPSD
Chase,
Did you rewire your GPR. Getting any codes?
Old Jul 29, 2008 | 06:57 PM
superduty4x4
I emailed Jody, and a simple re-wire of the GPR is all that's needed- you take the two leads for each bank off of where they are and put them on the center post (you have to modify that fancy little plastic cover if you want it to go back on). No codes... well at least no SES light. Runs quieter, shifts better, fuels better (judging by the black smoke out the tails when I matted it and EGT's hitting 950*). I posted on Sunday I think, I'll try and dig it up for you.
Old Jul 30, 2008 | 08:55 AM
bobmiers's Avatar
bobmiers
I don't know about other model years, but my 2000 F250 was not real easy. There is was no way that I could get the 10 mm bolt out without following the instructions in the Haynes book. Just not enough room for my hands and the wrench at the same time. The instructions are to remove tire and take the fender liner out -- I cheated and only partically removed the liner without removing the tire. Then it was a snap to get the bolt out and to the code. Did mine a week ago. I was looking because I discovered duct tape over the end of the PCM. (I've only had the truck 7 months.) Result of inspection revealed that at 'some time' there had been something connected to the edge connector -- cleaned etc.
