relays
Old Sep 28, 2002 | 10:13 PM
41Clay's Avatar
41Clay
relays
I bought a couple relays from radioshack and they keep on getting corosion looking stuff on them and stop working. Could the problem be from me doing something wrong or from the relays being poop. I use them to run the headlights. :-)
Old Sep 28, 2002 | 11:19 PM
kioolt's Avatar
kioolt
relays
Are you buying their automotive relay? Are you mounting them in the engine compartment in a place that will keep them from getting wet? Are you talking about green corrosion?
Old Sep 29, 2002 | 01:09 AM
41Clay's Avatar
41Clay
relays
yes, it is thier automotive relay, and it is safe inside the cab. The corrosion is green, white, and black.
Old Sep 29, 2002 | 01:31 AM
Mil1ion's Avatar
Mil1ion
relays
How humid is it where you live ?
Try putting some Di-electric grease on the contacts.
That should stop the corrosion.
[font color=red]Dennis
FTE Assistant Administrator
[/font]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
Old Sep 29, 2002 | 01:40 PM
41Clay's Avatar
41Clay
relays
It's really dry here. I think I put some on it, it might now have been enough though. Can that grease cook away if the contacts are to hot?
Old Oct 2, 2002 | 12:19 AM
924x2150's Avatar
924x2150
relays
Placing two dissimilar metals together will cause corrosion. If your contacts are hot, that means the gauge of the wire or thickness of the terminal is insufficint to bear the amperage used by your lights.Did you solder the terminals? A wire and terminal properly soldered will help make a good connection and fight corrosion.
Old Oct 2, 2002 | 03:30 PM
beartracks's Avatar
beartracks
relays
