Tran Temp is 145 without trailer, 200ish (210 was my highest) when towning 7000 lb travel trailer.
EGT's 600 to 700 without trailer, 1100 with travel trailer.
I do sorta wonder about just how hot things get in a stock truck. I can imagine going over 1200 EGT if I took off my mods and would never know it. Seems kinda scary.
Trans temps seem kinda high, you might want to install a cooler like stated earlier. Are your EGTs your max? Because they should fluctuate from 600-1200° depending if you are pulling a grade or not. My EGTs get kinda toasty pulling 10K, but usually only up grades.
If you really want us to spend your money, a 4" turbo back exhaust may get your EGT's a little lower. However, if you are only tickling 1100 degrees, you are still OK.
Ray:
In none of your posts where you mention 1100 degrees egt do you tell us which program you are running. If that is the DP tuner tow program, my experience is that its working well. My 40 tow program, pulling a 13000 lb 5th wheel on cruise control, gets the egt up to about that temperature on grades, and then it kicks the tranny out of OD into 3rd, causing the temp to drop. Its automatic, and protects against excessive egt in case I'm careless and forget to watch the guage. The 60 tow program should do about the same with your lighter trailer.
I agree you should consider another tranny oil cooler. I added a trucool to my 02, which already had an in-radiator cooler plus a oil-to-air cooler in front of the radiator. I put the trucool in series with those two, and have plenty of cooling. The only time I got near 200 was in a city, having just gotten off the highway. The slow speed and stoplights cut down the airflow and made the oil-to-air coolers less effective.
Warren
Originally Posted by rayashworth
Yes, that would be near LaCrosse/LaCresent.
I just made another trip and monitored the temp a little closer. Basically I am running between 900 and 1100. Mostly around 1000.
