Turn Signal Problem 88 Bronco!
Old Oct 3, 2002 | 12:30 PM
Mil1ion's Avatar
Mil1ion
Old Oct 5, 2002 | 06:39 PM
1988XLT2002's Avatar
1988XLT2002
I have a problem, when i turn on my turn signal either way both rear lights come on and blink and the front one turns on normal. When i brake and have my signal on the signal freeze until i let off the brake. So far i've replaced the thermal switch "makes the ticking noise" and the brake switch. Only two parts left to change, the turn signal switch and the main control unit in the column. And worst case a have a short somewhere.
Old Oct 5, 2002 | 09:02 PM
kioolt's Avatar
kioolt
I think you should check your grounds on the rear lights.
