A new wobble
Old Jul 28, 2008 | 01:21 PM
tndiesel's Avatar
tndiesel
A new wobble
Driving down the interstate I noticed a wobble. It's not in the steering wheel but seems to be toward the back, I think. Any thoughts?
Old Jul 28, 2008 | 02:30 PM
Neal 97 250's Avatar
Neal 97 250
Check lugs. I found some of mine backed off by themselves one time. Check to see if a wheel weight flew off.
Explain the wobble. Does it wobble side to side or an up down vibration wobble. Is it fats or slow?
Old Jul 28, 2008 | 02:39 PM
CampSpringsJohn's Avatar
CampSpringsJohn
Lug nuts, wheel weight flew off, a low tire, driveshaft u-joint coming loose. Possible steel belt seperation in one of the tires? Did you have a wheel lock up in an emergency stopping situation recently? If so, you probably have a flat spot on a tire. A bad shock absorber. Just some things to check.
Old Jul 28, 2008 | 02:45 PM
BlueMule's Avatar
BlueMule
And as long as your checking things out you might as well take a look at the leaf springs and u-bolts that hold them to the axle.
Old Jul 28, 2008 | 03:25 PM
tndiesel's Avatar
tndiesel
I forgot to mention that I had the driver's side outside dually tire balanced last week when they had to replace the valve stem. I had it balanced at Sears and they I watched the guy and he seemed clueless, it took him almost 35 minutes to balance 1 tire. I'm definitely no tire expert but it originally had 3 weights on it and he only put 1 but maybe it never takes the same twice? Also, I just checked my air pressure and on the passenger's side the inside dually tire was 70 pds air pressure and the outside was 61. The dirver's side inside was 70 and the outside tire was 48. I just checked all these tires about 8 days ago b ut since then have done quite a bit of farm off road driving, maybe it's the air pressure?
Old Jul 28, 2008 | 03:40 PM
CampSpringsJohn
They need to be the same air pressure. You may have found the problem. On some duallys there is a pin that sticks out from the hub. There is only one way for the wheels to go on. If the new guy installed the wheel and didn't line the small hole in the rim with the small pin, your wheel is installed improperly. My truck is a 10 hole hub, not an 8 hole hub, so it is different that yours. Your truck may not have the small pin I mentioned.
Old Jul 28, 2008 | 04:58 PM
WALJON's Avatar
WALJON
Very good info! and for sure something to check out
On my aluminum rims I lose weights all the time and I can totally tell when I get going down the highway and get the wobble and all it takes is one weight to come off ,so maybe that kid at the shop did screw it up.
Old Jul 29, 2008 | 08:05 PM
WALJON's Avatar
WALJON
Did you ask if the guy put the wheel on properly when you went back as john has suggested?
Old Jul 29, 2008 | 08:28 PM
scatgo's Avatar
scatgo
My truck does have the pin to clock the rims. When clocked the valve stems should be 180* apart.
