gear ratio
Old Jul 28, 2008 | 10:44 AM
n.o.yat's Avatar
n.o.yat
gear ratio
i have a 94 f-250 , 4x4. at 70 mph iam turning 2100 rpm.my current tire size is 265/75/r16. the truck calls for 235/85/r16. the original paper work on the truck says it had a 355 gear. but i have paper work showing that the rear end was canged. i am beliving maybe it is a 411 that is in it now. i know i acn take the cover off and cout the teeth, but off the top of your heads, what do yall think may be in there?
Old Jul 28, 2008 | 10:45 AM
quicklook2's Avatar
quicklook2
read the code on your door.
Old Jul 28, 2008 | 11:35 AM
skaterbro's Avatar
skaterbro
If you have paperwork showing that work was done to the rear end than who knows. Stock would be a different story.
Old Jul 28, 2008 | 11:52 AM
quicklook2's Avatar
quicklook2
count the revolutions of the wheel and the driveshaft.
Old Jul 28, 2008 | 02:25 PM
85e150's Avatar
85e150
At 70 mph, 32 inch tires, .71 OD top gear, 4.11 axle, you should turn 2144 rpm.
A 3.55 changes this to 1853 rpm.
Go here, second calc down, go further down for tire size calc.
Novak Conversions - Gearing & Gearing Math for Jeeps
Sounds like 4.10 or 4.11 to me.
Old Jul 29, 2008 | 06:48 AM
farmer2's Avatar
farmer2
This is the way I would check it too.
Put a chalk mark on the wheel/drive shaft and count the rotations of the driveshaft per 1 rev of the tire. If you dont have limited slip then make sure you mark both tires and keep them in sink with each other while turning the drive shaft.
