suspension problem
Old Jul 27, 2008 | 09:09 PM
1985 Ford F-150's Avatar
1985 Ford F-150
suspension problem
Last weekend I went campin/four wheelin the roads werent incredebly bad mostly washboards a few ruts and small rocks. Anyways on the way up I some how pulled my right front shock through the washer on the mount. I wasnt drivin fast over rough terrain or anyhtin like that. Also do you guys think i need new front springs cause I have 315 70 r16s on it and they rub on the fenders when I turn and go into a gutter? What do you think is wrong?
Old Jul 30, 2008 | 12:27 PM
1985 Ford F-150
dead thread
Old Jul 30, 2008 | 01:21 PM
Blue Bomber's Avatar
Blue Bomber
does this mean you found the answers you need?
Old Jul 30, 2008 | 07:15 PM
1985 Ford F-150
No just tryin to get it back to the top so someone would reply to it.
Old Jul 31, 2008 | 11:13 AM
Blue Bomber
oh, ok. i really dont know about the tire thing. did they just start rubbing? the shock could have broken on a hard bounce. any hard bounces?
Old Jul 31, 2008 | 11:20 AM
1985 Ford F-150
No they rubbed from day 1 on gutters when I would turn. The roads were pretty rough up there as far as washboards and ruts but I mighta hit one quick and forgot which one I hit.
Old Jul 31, 2008 | 11:28 AM
Blue Bomber
have you fixed the shock? i dosent sound like it was too bad.
Old Jul 31, 2008 | 12:08 PM
1985 Ford F-150
No im just runnin it for the time bein its not hittin anythin so I guess its ok. Do you think the front is sittin a bit low?
Old Jul 31, 2008 | 12:20 PM
Blue Bomber
i dont really know alot about wheel and tire combos on these trucks (im still running stock type stuff on a 2wd). would you be willing to put some spacers under the springs? that would give you about an inch. might help. how much bigger are the tires from stock?
Old Jul 31, 2008 | 05:54 PM
unrulee's Avatar
unrulee
So you want to fix the rubbing? I ran 35's on my 79 250 4x for a couple of years with only add a leafs up front (2" lift max). Since you have a 76 250 you fall into the high boy category and those trucks sit about 3"s higher than my 79 stock. So I don' think that you should be rubbing. I never did with my spring/tire combo, and yeah I got it into some pretty twisted up situations. I'd say that your front springs are sagging, so you can either get some add a leaves to bring it back up (cheap, will last a while but kind of a band aid) or (what I would do money permitting) get some new front springs.
Old Jul 31, 2008 | 07:57 PM
1985 Ford F-150
Yeah im runnin 315s with about 1 1/2 inch tread on em. I know you guys dont like lmc but they have fronts for 159 a pair can any body else beat that I have the 6 leaf fronts on it.
Old Aug 1, 2008 | 11:40 PM
1985 Ford F-150
Well finally got around to puttin on new shocks. I put em on at full droop and they had about an inch or two till they bottomed out they are the same lenghth as the old ones. I think that what happened was as I was makin my way down the road the frame and body were gettin tossed around too much and resulted in forcin the suspension to extend more than full droop. Also when I jacked up my truck and let the susp. hang the tires just cleared the ground and it only say up in the front two or three inches more than the back. The springs and bumpstops had about 6-8 inches between em so I certain I need new springs. The above post was meant to say can any other company beat the price not tryin to bum em off anybody.
