Up Fitter Switches
Old Jul 26, 2008 | 11:39 PM
Misery's Avatar
Misery
Up Fitter Switches
Need some help with this one.
I have 06' f250 SD, with the up fitter switches.
switch 1 PIAA 580, switch 2 PIAA 540, Switch 3 PIAA 520, Switch 4 PIAA 510 (NEW). Whne we added the 510 to switch 4 and turn them on they work great, problem is the light on switch 2 (540) will not work. I have power light on at switch, and power at the wire going to power on thr lights, just no lights turn on.
Could this be a relay problem, or a bigger amp fuse.
ANy help would be great.
Old Jul 27, 2008 | 12:03 PM
Franklin2's Avatar
Franklin2
Here's some info. The last two circuits are lighter duty(only 10 amp) and you cannot stick a bigger fuse in without danger of overheating the wiring.
https://www.fleet.ford.com/truckbbas/non-html/Q117.pdf
Old Jul 27, 2008 | 12:13 PM
Misery's Avatar
Misery
Still why would somethng connected to the switch four lead knock out what was on switch two
Old Jul 27, 2008 | 12:38 PM
Franklin2's Avatar
Franklin2
The link I gave you has a diagram. You may have a wiring problem with your lights.
