Revving while a/c or heat on?
Old Jul 26, 2008 | 08:05 PM
bigbad'945.0's Avatar
bigbad'945.0
What gives? My truck wastes enough gas as it is, on the very very rare occasion that I run the a/c, usually when it rains during the day, it revs while it's on! Ahh!!!
Old Jul 26, 2008 | 10:17 PM
quicklook2's Avatar
quicklook2
the vacuum line is leaking.
Old Jul 27, 2008 | 10:30 PM
bigbad'945.0
as in i need a new vaccuum line or what? how do i go about diagnosing and fixing this problem?
Old Jul 28, 2008 | 03:23 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
are you sure it isn't just the PCM idle adjust for when the a/c compressor clutch is engaged?
I know that every single F-150 in my sig did that crap. idle would drop 100-200 rpm and then pick back up about 50-100 rpm above where it initially was. only did it when the A/C or the defrost was on
Old Jul 28, 2008 | 10:06 AM
quicklook2's Avatar
quicklook2
the vacuum line that controls the settings.
follow it to see if it leaks.
