Engine Swap Questions
Old Jul 26, 2008 | 04:46 PM
tenforty_2's Avatar
tenforty_2
The engine swap threads don't seem to have all of the answers.
I have a 1978 F-250 2wd w/ factory 460 / c6. I will be putting the 460 into a 1979 F-250 4wd w/ factory I 6 / 4 speed.
What I know:
Will need a 351/400 bellhousing, 390 flywheel & clutch.
Rear sump pan.
What I don't know:
What factory towers and mounts will work?
Will the alt & power steering pump brackes from the 2wd work?
Trying to avoid paying $2700 for the kit from L&L
I will probably buy thier headers!
Old Jul 26, 2008 | 05:49 PM
tankrsc's Avatar
tankrsc
Don't know about the tower and mount part, but the power steering and alt brackets shouldn't be a problem.
Old Jul 26, 2008 | 06:47 PM
Rebel Warrior's Avatar
Rebel Warrior
Exclamation RE: Engine swap
351M/400 Frame stands should work. if not available L&L you'll need L&L insulators(mounts)
The Alt will not fit with Factory Brackets. it will hit the crossmember. L&L
The PS brackets need to be from a truck. where the pressure hose comes out of the pump(close to the steering box!), some will bend the bracket up to provide more clearance. that's not me. If you can come by a set of saginaw brackets & pump(off some Lincolns). & change the hose end.
You'll need a 351M/400 or 460 Bellhousing, clutch, cover. (as far as I know 390 flywheel won't fit a 460.
Rear sump pan.
A pan from a E350 with 460 will work nicely, or later "81 & later F250/350 w 460, they are rearward sump(not all the way at the rear but enough to work great)
these are great headers, I'm still on my first set after twenty years. but I live in CA.
You'll love the power of a 460 in there!
Old Jul 27, 2008 | 05:21 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Econoline rear sump 460 pan: 1975/91 E250/350.
Old Jul 27, 2008 | 05:33 AM
duste's Avatar
duste
Factory 351/400 frame mounts will work but the 460 engine mounts would need to be modified. Easiest way is to get the 460 truck towers.
The bell housing from a 351M/400/429 or 460 will work but I can't see the 390 flywheel working.
Since you have the whole donor truck you should have any trouble with brackets, just swap it all from the 460 truck and you should be good.
Have fun
Old Jul 28, 2008 | 07:42 AM
tenforty_2's Avatar
tenforty_2
Thanks guys!
Old Jul 29, 2008 | 01:54 AM
65f100_352's Avatar
65f100_352
I did the 460 swap into my 78 f250, and I used a set of motor mount plates off ebay. no problems so far(knock on wood).
Old Jul 29, 2008 | 07:28 AM
tenforty_2's Avatar
tenforty_2
What flywheel, clutch and pressure plate did you use?
Old Jul 30, 2008 | 12:15 AM
65f100_352's Avatar
65f100_352
My truck has an auto, sorry. The only thing I could think of is look up the clutch setup for a 79 2wd pickup. ZZZ-MU1011-1 is what they show at summit racing. Not sure on what year of flywheel would fit your truck though.
Old Jul 30, 2008 | 02:01 AM
bmarkline's Avatar
bmarkline
I just got L&L's fenderwell headers for my 460 swap w/C6. (ditched a 351m) After dropping in the engine, I realized I should have stuck the headers in first. Looks like my easyest option now is to loosen the front clip and tilt it forward to slip the headers in between the fenderwells and the frame. Might have to undo the steering shaft too, not sure yet. But yeah the headers look tough as nails.
Old Jul 30, 2008 | 03:50 AM
NumberDummy
Ford didn't offer a manual transmission on a F Series truck with a 460 engine till 1983. No cars w/460's ever came with a M/T.
What we used to do prior to 1983 was use the Mustang/Torino 429 manual trans clutch parts & flywheel because there was nothing else available then.
Now all you need is the 1983 and later parts.
oregontrailsman
Engine Swaps
Nov 12, 2014 07:12 PM
dirtmister16
13
Jul 21, 2014 11:03 PM
stromburg
Oct 11, 2012 09:43 AM
Hickfied
Engine Swaps
Sep 27, 2009 01:32 PM
snydermotive
Jan 10, 2004 09:18 AM
