Buzz noise behind the dash.....???
Old Jul 26, 2008 | 10:46 AM
stroke-of-luck00's Avatar
stroke-of-luck00
whenever i turn my key to on to warm the glow plugs, I hear a loud buzz noise that sounds like it's coming from the dash. I have no clue what it is but it's annoying for sure. here is a vid of the sound...right about the 4 second mark. any ideas would be appreciated!
http://www.youtube.com/watch?v=7JOU1k_Lk3w
Old Jul 26, 2008 | 10:54 AM
Tenn01PSD350's Avatar
Tenn01PSD350
Sounds to me like a relay energizing. If the buzz continues it is likely that your batteries are getting weak or have a bad connection. Yours seem to go away quickly so I don't see too big a problem. It starts right up right? At least that is my guess from what I saw/heard. Hard to diagnose some things from a computer.
Old Jul 26, 2008 | 10:56 AM
stroke-of-luck00
my batteries are less than 6 mo old so I'm not sure if that's it. i'll check my connections again. it starts up just fine. i guess i'll really be able to tell when (if) it starts to get cold again.
Old Jul 26, 2008 | 10:58 AM
mueckster's Avatar
mueckster
I was thinking along the same line. Does the sound seem to be coming from behind the radio area?
Old Jul 26, 2008 | 11:07 AM
clintbonnie's Avatar
clintbonnie
I have the same buzz.. always thought this was the air vacuum pump for the hubs..when it is up to pressure, it shuts off.. I'll do a test later and get back to post my results..
Old Jul 26, 2008 | 11:11 AM
stroke-of-luck00
the noise i have is def not the vac pump. i know what that sounds like and this is different. guess i'll have to start digging!
Old Jul 26, 2008 | 11:32 AM
Markadeck's Avatar
Markadeck
Gone, but not forgotten
I've had the same problem for years but mine is even worse. It turns the radio on, or switches over to cd even when there is no cd in the disc drive. Mine seems to happen only in cold weather though.
