motor miss
Old Jul 25, 2008 | 06:03 PM
vivojr21's Avatar
vivojr21
motor miss
my motor is missing at idle-1500 rpm. can some give me some segestions on what this can be.
Old Jul 25, 2008 | 06:31 PM
clux's Avatar
clux
I assume you are having a knock at idle, that goes away when you rev it up, is that correct?
Also, how many miles on it?
Old Jul 25, 2008 | 08:24 PM
vivojr21's Avatar
vivojr21
yes also lots of shaking. its got 201000 miles just change the set of injectors 100 miles ago.
Old Jul 25, 2008 | 08:46 PM
medhvac's Avatar
medhvac
are those remans or new ones! (injectors)
Old Jul 25, 2008 | 08:53 PM
vivojr21's Avatar
vivojr21
remans got them on ebay
Old Jul 25, 2008 | 09:01 PM
medhvac's Avatar
medhvac
well ive had my share of injector problems and i replaced all of mine with (new) ones i really dont believe in remans thats why i asked! I hope the the remans are not ur problem!
Old Jul 26, 2008 | 01:17 AM
clux's Avatar
clux
Did you replace your wiring harnesses and valve cover gaskets when you did the injectors?
Old Jul 26, 2008 | 07:05 PM
vivojr21's Avatar
vivojr21
no i did not. is that a need?
i drove the truck some more today when the od kicks in and the rpms drop below 1500 the truck starts jerking like no power. what in hell can this be. also does it on take off
Old Jul 26, 2008 | 07:46 PM
clux's Avatar
clux
I had the wiring harness under the valve covers fail almost immediately after changing injectors. I think flexing the insulation on wires that have that many miles is just too much for them.
Another thing to check is your oil level. Low oil might also cause your symptoms.
trebor_9513
22
Oct 18, 2008 03:54 AM
corys46
Modular V8 (4.6L, 5.4L)
13
May 5, 2008 07:45 AM
imatalisman
Aug 22, 2007 08:31 AM
bakes
Dec 4, 2003 04:38 AM
