Sponsored by: Real Truck
Using Trans fluid as fuel
Old Jul 25, 2008 | 05:00 PM
racer129z's Avatar
racer129z
Has anyone had any experience using trans fluid as a substitute for diesel. I have a local Ford diesel tech that claims he has used trans fluid for 100k miles with no problems. I have an unlimited supply of used fluid but not enough nerve to try it. It will only work in a 7.3 for some reason. I just dont see that trans fluid has same viscosity and does it burn?
Old Jul 25, 2008 | 05:20 PM
rollerstud98's Avatar
rollerstud98
it'll burn, but definitely not something I would do in my truck, I do have a 6.0 though, but I still wouldn't want to subject my injectors to that no matter what I drove.
Old Jul 25, 2008 | 05:21 PM
ReAX's Avatar
ReAX
You got me.
I know some military multi-fuel engines say they will run off anything but AV-jet. If it can burn fuel oils, kerosene, gas and diesel, what is one more low octane petroleum product?
I wouldn't try synthetic though.
Old Jul 25, 2008 | 05:36 PM
Heavy_Metal's Avatar
Heavy_Metal
what is AV-jet? I'm an aircraft technitian and never heard of it. Avjet is an aircraft fuel company as far as I know.
Old Jul 25, 2008 | 05:50 PM
caprang's Avatar
caprang
You can mix ATF with diesel but never heard of using it straight. Dont think I would recommend that. There is another thread on here about using 2 stroke oil as an additive and that is by far the more popular choice with the 7.3's and 6.0's that I run with. Claim to pick up MPG and its quieter.
Old Jul 25, 2008 | 05:55 PM
ReAX's Avatar
ReAX
I can't remember which of the aviation fuels is jet, av1 or av2, so I just use AV-jet for jet fuels. So i guess it's the highest octane kerosene at the airport.
Old Jul 25, 2008 | 06:45 PM
redford's Avatar
redford
FTE Leadership Emeritus
Originally Posted by ReAX
I know some military multi-fuel engines say they will run off anything but AV-jet.......
The military multifuel vehicles will burn anything that is flammable and has lubricity. They demonstrated (while I was in the Army back when Carter was president) that you could drain off half of your crankcase oil, dump it in the fuel tank and get 5-10 miles down the road in an emergency.
I drove a Gamma Goat on 50/50 #2 diesel and gasoline, about 70% #2D and kerosene, #2D and paint thinner, I didn't try it but I know one guy dumped some charcol starter fluid in his tank.
http://www.flmvpa.org/member_vehicle...ama%20Goat.jpg for a picture of a Gamma Goat, if you don't know what they are.
Old Jul 25, 2008 | 06:56 PM
ReAX's Avatar
ReAX
The old Duce and a Halfs our sherrif's Dept bought say clearly not to burn the jet variety of av fuel. Newer engines might be better.
Old Jul 25, 2008 | 07:20 PM
redford's Avatar
redford
I wouldn't mind owning an old duece-and-a-half multi fuel truck. It's be a fun rig.
Old Jul 25, 2008 | 09:18 PM
ReAX's Avatar
ReAX
They aren't fun in a parking lot, but if you can get it rolling before you turn they are a hoot. That old turbo diesel is loud, no ac, no radio, but it should go just about anywhere.
Old Jul 26, 2008 | 08:20 AM
guy skip mitchell's Avatar
guy skip mitchell
I drove one of those multi fuel 5 tons 53mph down hill with the wind at your back,it locked up one day at 53mph what a ride until I pushed the clutch in.
Old Jul 26, 2008 | 01:44 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
AVGAS is Aviation Fuel = 115/145 octane for gas engined planes.
JP-1, 2 and 3 and 4 are jet fuels....Doubt if you can find 1 anymore...maybe not even 2. Most use JP4 today....higher flash point = safer to use. Still lots of JP-3 still around too I think.
Old Jul 26, 2008 | 03:03 PM
05pstroke's Avatar
05pstroke
My brother has been running it in his Cummins for over 2 years now. He puts 5 gallons of diesel and fills the rest up with old, filtered transmission fluid. Says it averages $1.47/gallon. I have the 6.0L powerstroke and don't think I'll be trying it.
Old Jul 26, 2008 | 05:11 PM
DAFBFD58's Avatar
DAFBFD58
What your talking about using jp4,5,8 are trucks like the crash trucks p-2, p-4, p-15, p-19. The reason the dueces say don't use the JP fuels is because there are alot of military vehicles can use JP and there were few that could not.
