Adding a door lock...
Old Jul 25, 2008 | 03:19 PM
03F2507.3's Avatar
03F2507.3
When I bought the truck it had no outside key hole for the door locks. Im wondering if I can add a keyed handle with lock or should I look into the Ford keyless push button system?
I thought maybe someone might know of an inexpensive fix for this problem???
Old Jul 25, 2008 | 04:17 PM
indebt's Avatar
indebt
the PO had to have replaced the fronts to a rear handle set. Alot of f-250 keys can open most trucks, try on one of your friends and you will probably be able to open his. Its piece of mind!
Old Jul 25, 2008 | 08:35 PM
03F2507.3's Avatar
03F2507.3
Anybody know where to get new door handles with key holes online? One of our sponsors maybe?
Also, what about the Ford keyless entry pad? A good option or not?
Old Jul 25, 2008 | 08:44 PM
PaysonPSD's Avatar
PaysonPSD
Both are available on Ebay. Sorry I don't have any links for you.
Old Jul 25, 2008 | 08:52 PM
F350-6's Avatar
F350-6
I've been thinking about the keyless pad myself. Th!nk Parts Guy
Old Jul 28, 2008 | 11:16 AM
FTE/PARTS-GUY's Avatar
FTE/PARTS-GUY
Former Vendor
leave the door handle w/o hole on the truck. to many thiefs out there break into these trucks. add the keypad and use your remote to enter your truck.
Ed
Old Jul 28, 2008 | 04:13 PM
superduty4x4's Avatar
superduty4x4
Hey Ed, how much $ for the key-less handles? Any idea how hard it is to add a factory door keypad to the truck?
And, what to do if you ever lose your remote or it dies?
Old Jul 28, 2008 | 04:57 PM
FTE/PARTS-GUY
Former Vendor
7L2Z14A626BA list is $85.00 sell price check my site.
the factory hard wire style I dont think can be done, really not sure.
you need keyless entry for this to work. the little key fob push button deal. This would be used mostly if you lock your keys inside or battery went dead in your fob. The battery in the key pad will more then likey out last the truck.
Now if you had a dead truck battery then you would need to get that battery replaced first.
need year make model of your truck to make sure of part number on door handle to get you part number.
Ed
