Sponsored by: Real Truck
wheel question
Old Jul 25, 2008 | 12:41 PM
kupiec20's Avatar
kupiec20
wheel question
16x10 with a 3.5 backspacing, what does that 3.5 mean?
and would these rims take a 315 75/r16
Old Jul 25, 2008 | 01:01 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
https://www.rsracing.com/tech-wheel.html
Wheel/Backspacing info from the 4X4 Tech Thread
Old Jul 25, 2008 | 04:19 PM
Smokeispower's Avatar
Smokeispower
Backspacing
Just another way to express where the hub is positioned in the wheel. 3 1/2 backspacing means that's the distance from the back of the hub to the inside edge of the wheel, which means on a 10 inch wheel, the other 6 1/2 is to the outside edge, and the offset is (half of 6 1/2 less 3 1/2) one and a half inches.
Very important if you're putting wider wheels on your truck - need to keep the backspacing pretty close to the stock wheel backspacing, or things start to rub.
Old Jul 25, 2008 | 08:59 PM
DCSpecial's Avatar
DCSpecial
Since you are looking at 16s....I'm guessing you have a 99-04 truck. Ideally you'd like to stick around 4.5" of backspacing.
With 3.5" they will stick out pretty far and place more stress on front end components.
