97 Expy eats #4 plug
Old Jul 25, 2008 | 12:18 PM
vicv's Avatar
vicv
My 97 Explorer 4.0L code X is really rough on the #4 plug, I have to change it on a regualr basis. CEL throws 304 code, misfire #4. After I change the plug and reset the PCM I am good to go for anywhere from 2 weeks to 2 months but when it starts to runs rough I know the code is gonna pop again. I've used Autolite AP103, Bosch (no good), Champion, Denso (why?) all with the same result.
I've changed the coilpack about a year ago, upper/lower mainfold gaskets 2 yrs ago, injector cleaner now and then. Any ideas out there?
Thanks
Old Jul 25, 2008 | 01:26 PM
jasongt06's Avatar
jasongt06
it could be a bad injector on the #4 cylinder.
Old Jul 25, 2008 | 06:03 PM
marragtop's Avatar
marragtop
Try switching the plug wire with another one and see if the problem moves to a the other cylinder.
Old Jul 25, 2008 | 09:34 PM
thelonerangerxlt's Avatar
thelonerangerxlt
I too would suspect a bad plug wire.
If you have an ohmmeter, you can test it; should have about 6-10K ohms per foot of wire. The number 4 is the longest of all the wires, and therefore has the most resistance.
Old Jul 25, 2008 | 11:59 PM
Bear River's Avatar
Bear River
Former ******
If the plug is fouling out, I would second the wires as a possible culprit. If the plug is eroding away at an accelerated rate, I would be led to believe that the cylinder is leaning out, due to a plugged injector, leaking intake manifold, etc.
Old Jul 27, 2008 | 08:31 PM
vicv's Avatar
vicv
Thank you guys for the suggestions. I was beginning to suspect the wire but not the injector.
