starter instalation
Old Nov 3, 2002 | 01:44 PM
Mil1ion's Avatar
Mil1ion
starter instalation
I use a deep socket with a U-Joint attachment and about a 12-16" extension on a ratchet.
[font color=red]Dennis
FTE Assistant Administrator
[/font]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
Old Nov 3, 2002 | 02:13 PM
terrylbu's Avatar
terrylbu
starter instalation
[updated:LAST EDITED ON 03-Nov-02 AT 03:16 PM (EST)]I`m not much of a mechanic but I try, My question is, my starter needs changed and I have removed the cable and the first two bolts how do I get up and around to get the third or is there even a third? I think I felt a third but how do you get a wrench to it. Im trying to learn so please help me I can use any tips or advice you can give. Thanks also I better tell you its a 68 250 camper special with a 360
Old Nov 4, 2002 | 03:44 PM
krazdndenver's Avatar
krazdndenver
starter instalation
I think the one you are talking about is accessed from the top. It is much easier to remove this one first as the starter will not try to come out if other bolts ar in it. If removed last the starter will try to come out while you loosen the bolt, making it more of a job then it has to be ( I learned this the hard way, that is why I remember this). Also this should be the last one installed. Hope this helps.
Robert
72 F100 Ranger XLT W/ 86 5.0L EFI W/ AOD
krazdndenver(No Email Addresses In Posts!)
www.geocities.com/krazdndenver
Old Nov 5, 2002 | 05:00 AM
terrylbu's Avatar
terrylbu
starter instalation
thanks alot for the info. I broke it loose from the top. then I was able to get extension on ratchet over top of starter, and held starter with one hand and ratchet with other. came out so smooth I think I got it down to a science. the getting your body and arms in right position was the hardest thing. Its kinda tight under there with a belly. LOL
Old Nov 5, 2002 | 07:31 AM
fordinlinesix's Avatar
fordinlinesix
starter instalation
Mil1ion
General Automotive Discussion
Mar 1, 2006 06:02 PM
Mil1ion
Texas Chapter
Oct 25, 2002 09:06 PM
Mil1ion
Aug 7, 2002 03:33 AM
Mil1ion
Appearance & Dress-Up
Jul 20, 2002 11:26 PM
Mil1ion
May 28, 2002 10:52 PM
