Sponsored by: Real Truck
Future maintenance
Old Jul 24, 2008 | 08:23 PM
john3390's Avatar
john3390
Future maintenance
I have a 2004 3/4 ton 6.0 with an automatic trans. I have 178,000 on the vehicle and have not changed anything but fluids, filters, brakes and tires.
Should I start planning on changing belts and hoses around 200,000?
Any problems with alternator or water pump I should be planning on?
Engine and trans run great.
Old Jul 24, 2008 | 08:28 PM
F350-6's Avatar
F350-6
Alternator, starter, water pump are hit and miss items. I'd guess on the alternator going first.
I hope you have changed your serpentine belt by now.
Old Jul 25, 2008 | 12:45 PM
john3390's Avatar
john3390
No - I check the belt everytime I change or check the oil. No cracks or frays anywhere.
Old Jul 25, 2008 | 03:00 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
You better have a spare belt, recommend changing belt at 100,000 miles. I would change hoses, thermostat to 203* stat, billet thermostat housing, new bolts from IH, and BELT.
Old Jul 25, 2008 | 04:21 PM
05lariatPSD's Avatar
05lariatPSD
I may be off base here, but I would be worried about the belt stretching and causing unneccesary wear on other components. It's cheap enough that I would replace it.
