1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Hot air from vents
Old 07-24-2008, 07:32 PM
deanjet's Avatar
deanjet
deanjet is offline
Hot air from vents
I have one of them there fancy pants air conditioning control systems that ain't got none of them there **** dohickies. Well, purely in the interest of science I decide to turn of the a/c and and use the vent setting to see if my gas mileage would go up. Bear in mind, I live down yander in the swaps of S. Florida, so I have never, and I repeat, never used the heat in this here truck once. So I wait and sees what happens..... Lo, and behold, there was some very toasty air blowing from them there vent thingys. Now this leads me to believe that I might just be having some nice warm radiator juice bleeding into the heater core, causing my vents to blow warm. What do ya'll think?
Old 07-25-2008, 07:48 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
Cute.
Coolant always flows though the heater core.
Check the operation of your blend door.
Old 07-25-2008, 07:38 PM
mbwrench's Avatar
mbwrench
mbwrench is offline
you may also be getting a lot of heated air from off the engine and hood livin'down thar.
Old 07-25-2008, 09:00 PM
deanjet's Avatar
deanjet
deanjet is offline
Ya don't say! Well, them Detroit boys done did it now.
Old 07-26-2008, 11:10 AM
alloro's Avatar
alloro
alloro is offline
Received 4,253 Likes on 2,479 Posts
Except on Max A/C with the temperature turned all the way to cool. In this case, vacuum closes the heater control valve (if equipped) and stops flow to the heater core.
