Screamin Turbo
Old Jul 24, 2008 | 04:53 PM
Smokin''s Avatar
Smokin'
Smokin
Originally Posted by SONNYKRU
Thanks Lisa...
Yep sure thing. Just think about it this way... when you are towing, and at an elevation (and a change in atmospheric pressure), your truck works harder to force in all of that air it needs, and as a turboed vehicle, it's forced induction so your turbo has to work a lot harder - and therefore it complains about it a bit more, hence the "scream" you hear.
Do you have a boost, EGT guage? If you're running your turbo that hard, you might be getting those exhaust gasses reeeaallly hot, too....
I live at about 6,000 foot, and when we go camping or whatever we reach as high as 13,500 with the truck..and you should hear that turbo scream. I had someone tell me once that it sounded like a pissed off puma.
Edit..didnt see all these new posts...you should take your hoses off and check that thing out just to make sure. The noise I have in mind may be different. Would be nice to hear this roaring.
Old Jul 24, 2008 | 05:08 PM
papadelogan's Avatar
papadelogan
Snowboard season cometh..
Originally Posted by miller_feed
Sure its not you fan kicking in? If it only happens when you pull a grade. Have you heard your fan kick in? Sounds like a giant roorrrr.
You're referring to the radiator fan, yes? I think it was Eugene & Kwik that talked most about the incredible noise that the radiator fan has its clutch lock up. It only happened when the truck was working really hard, IIRC. That might be what you're hearing.
Old Jul 24, 2008 | 05:10 PM
ron's power stroke's Avatar
ron's power stroke
Originally Posted by superduty4x4
Isn't anyone going to tell this guy to ditch the K&N and replace it with a 6637 to save his turbo and engine? Where are your manners?
My 99 is an early and the turbo does wail... a quick look at the turbo will tell you if it's an early or late model- the late models have reinforcement ribs at the inlet where the intake attaches to the turbo, the earlys don't have those ribs.
the early bird also has 4 bolts holding the the compressor housing on..the later trucks have 5 bolts.... i think Rick hit it... its the fan he is hearing..like Lisa said..if she runs good and doesnt miss a beet..you should be ok...
Old Jul 24, 2008 | 07:04 PM
SONNYKRU's Avatar
SONNYKRU
There are reinforcement ribs at the inlet. I'm leaving in the morning for a 9 day camping trip at the Jersey shore so things will have to wait until I get back. Thanks everyone for your input, I will consider one and all. Thankfully there are no mountians on the way to the Jersey Shore.
Old Jul 24, 2008 | 09:13 PM
bigsteve1969's Avatar
bigsteve1969
i was going to get around to it after i found out more info but things lead me away from the computer i had to run to town for errands ha ha but yea ditch the k&n and go with the 6637 and you can still make use of that k&n tube if im not mistaken right guys>??
Old Jul 24, 2008 | 11:59 PM
superduty4x4's Avatar
superduty4x4
Should still be able to use the K&N intake tube but it may need to be shortened a bit to get the 6637 on the end of it.
Old Jul 25, 2008 | 06:53 AM
SONNYKRU's Avatar
SONNYKRU
Who makes the 6637
Old Jul 25, 2008 | 07:34 AM
bigsteve1969
its a napa filter go to fleetfilters.com and type in 46637 (thats the part number) and then holler at pete to get a cover
Old Jul 25, 2008 | 09:14 AM
countrykid_86's Avatar
countrykid_86
I have a 2002 PSD and my turbo screams when I am running between 1500 and 2000 RPM, say when I am going up a hill and you would expect to hear a whistle. If it is at higher RPMs then it whistles like it always has, but I started noticing it after I had replaced the stock air box with a 6637 and one of Pete's filter covers. I took my pipes off and the turbo seems to be fine, no play at all no excessive oil and the fins look good. I am writing it off as the turbo being louder (easier to hear) with the 6637 filter. Maybe it is the same with your K&N since you don't have the stock air box on anymore.
This may be a stupid question but does anyone know if elevation affects the turbo at all, I live at over 5,000ft. Also if there were an exhaust leak or the EBPS (Exhaust Back Pressure Sensor) were fried, does anyone think that would effect the turbo and make it scream.
By all means get a 6637 and throw the K&N in the dumpster, I made the exact same mistake wasting a bunch of money on a K&N and then through it away because I wanted to save my turbo and engine.
Old Jul 25, 2008 | 12:05 PM
farmb0y's Avatar
farmb0y
I'll be odd man out here, if you are maintaining your K&N filter properly, there's no reason you can't leave it on there. I've run one for around 100k miles, and played around with the 6637, and I notice no difference between the two. I actually think the K&N does a better job. I have the 6637 with a cover on it right now and just the other day I was able to wipe the inside of the intake tube and leave a mark, could never do that with the K&N.
Key with the K&N, they have to be maintained!!! otherwise they are junk.
With your roar, you may just be working your truck hard enough and it's the fan kicking it, it can be noisy enough to drown out the engine noise. If your turbo was making a bad of a noise as you say, I think you'd be seeing a lot of smoke and have no power.
Old Jul 25, 2008 | 01:33 PM
bigsteve1969
farmboy what is the downtime due to cleaning the filter? i had a k&n pan style filter and it just took to much time for me to be cleaning it every week. and i agree with your point on maintaining it but maint. is the KEY to everything on these trucks but i think k&n doesnt emphisize this enough i mean there selling point is a million mile filter.. but to each his own
Old Jul 25, 2008 | 01:38 PM
Smokin''s Avatar
Smokin'
Smokin
FWIW...I have an airraid on mine. Everyone on here told me I should get rid of it, but I clean it and oil it at each oil change, and my intake hose is always spotless, I always run a clean white rag up in there and I never come out with anything.
Old Jul 25, 2008 | 03:24 PM
  #28
farmdad's Avatar
farmdad
I think cleaning it every week is a little too often. Like Lisa said, every oil change is a good time to do it. I've gone a couple oil changes (5k miles per change) and haven't had issues. I may have "charged" it by putting a little bit more oil to it from the inside. It does take time to clean it, letting it dry after washing/cleaning it is what takes most of the time. I will clean mine at night and let the filter dry out over night, sometimes with a fan to it. Then I can oil it in the morning good and I'm ready to go.
I think with these covers everyone uses on the 6637, put one on a K&N or airraid will do just as much good or better for these filters.
Someone asked, you can use the intake tube from the K&N FIPK setup to use on the 6637. That's the way I have mine hooked up. I did have to remove the heat shield around the filter because the 6637 is too big it didn't fit.
Last edited by farmdad; Jul 25, 2008 at 03:25 PM. Reason: wrong poster, the old man needs to learn out to log out!
Old Jul 25, 2008 | 03:35 PM
  #29
Smokin''s Avatar
Smokin'
Smokin
mark - I know this is OT..but I PMed you on the questions you asked me. Did you ever get it?
Old Jul 25, 2008 | 03:37 PM
  #30
bigsteve1969
well i know on my panel type k&n filter i couldnt keep it clean it was just packed with bugs and debris every friday ha ha thats why i switched to a 6637
