Squeaky ashtray door - 2004 FX4
Old Jul 24, 2008 | 10:52 AM
Damon_Tirerack's Avatar
Damon_Tirerack
Former Vendor
When mine gets cold it rattles in its holder all the time. I don't smoke and don't care to continue driving around all the time with it open to keep it quiet. It seems to be coming from behind it, but goes away when opened.
If anyone has had the issue or can weigh in I would appreciate it.
Old Jul 24, 2008 | 11:38 AM
SteveVFX4's Avatar
SteveVFX4
there's actually a TSB that shows how to fix it but I can't find an active weblink for it right now. But basically you have to take your ashtray out and put foam tape on the bottom 3 pins of it. I did this to mine over 2 years ago and it hasn't rattled since.
To remove the ashtray, you first have to remove the trim piece around the radio/hvac controls.
Old Jul 24, 2008 | 12:03 PM
Damon_Tirerack
Former Vendor
Thanks. Is pulling that panel off a matter of grabbing and pulling, or is there a procedure to doing it?
Old Oct 7, 2008 | 03:30 AM
redrush40's Avatar
redrush40
Yeah, mine does that same rattling.
I have a 05 FX4.
Best way is to follow the recall, put foam or padded tape under the actual pull out trey, or simply remove the trey all together.
TONY Z.
#40
grandpawj
17
Nov 2, 2012 11:38 AM
Mayerstom
Nov 5, 2011 09:43 AM
Ryan50hrl
2004 - 2008 F150
Aug 27, 2011 06:40 AM
bobert2412
6.7L Power Stroke Diesel
13
Aug 18, 2011 02:31 PM
turkyhntr
2004 - 2008 F150
18
Jan 2, 2006 06:26 AM
