Aerostar Ford Aerostar
Hi and Help
Old Jul 23, 2008 | 07:46 PM
betzer's Avatar
betzer
Hi and Help
Great forum, lots of info. Have 94 shortie 3.0. Runs great. Fan blade is cracked and looks like its ready to blow. Any options to replace other then dealer wanting $100.
Old Jul 24, 2008 | 06:56 AM
96_4wdr's Avatar
96_4wdr
welcome betzer
any auto parts store
replace the thermo fan clutch also. probably worn out and wobbly, broke the blades loose
or our FTE sponsor RockAuto.com
Old Jul 24, 2008 | 07:49 AM
VanGo's Avatar
VanGo
Another option: get a fan from a salvage yard, but get a new fan clutch. There's also some info in the archives about converting to an electric from a Taurus or Sable.
Old Jul 24, 2008 | 08:42 AM
aerocolorado's Avatar
aerocolorado
These are always available on eBay as well. The blades are mounted on a metal core. The cracks look scarey but there is little danger of emmient separation. As mentioned, replacing the fan clutch is a good idea. You'll need special wrenches to get the fan off. Auto parts stores have loaner wrenches. They are often the cheap, flat stamped design and as such, the wrench opening can be spread open too far to be useful. Check this before taking them out of the store. If the opening does not appear perfectly "square" ask for another set.
Old Jul 26, 2008 | 11:26 AM
marty600's Avatar
marty600
The 3l fan comes off easy, the 4l is tougher...I do not think the 3 needs that monster wrench mentioned above, I have done both, but it has been awhile since i owned a 3l..i do know that i did not buy/rent any tools to do so, but on the 4, i did.
Old Jul 26, 2008 | 11:51 AM
betzer's Avatar
betzer
Thanks for the replys. Used a 10 inch vise grip to hold water pump pully. Works very well. Tried a flex fan w/spacer, not to good. Would filling the fan cracks with JB weld throw it off balance?
Old Jul 26, 2008 | 09:02 PM
marty600's Avatar
marty600
Because the cracks are close to centerline, i doubt it...but i don't think the plastic will adhere well enough to any epoxy to prevent a blade separation..as mentioned above,
they usually don't do that?? I ditched my cracked 4l. fan and went electric (taurus 3.8l)
and powered it with a "DC" control, works good. It's the 4l fans that were the bad ones, surprised to hear your 3.0 went bad.
gnspmusa
New Member Introductions
Mar 8, 2008 03:08 PM
tmbrhg
Jun 24, 2007 02:09 AM
chuckshew
Feb 8, 2005 07:29 PM
rollingthunder3126
Oct 18, 2004 11:01 AM
fizzdive
Sep 6, 2004 01:07 AM
