2001 Explorer XLT Trans problem
Old Jul 23, 2008 | 05:28 PM
Diamond-X's Avatar
Diamond-X
I've been lurking around searching for the answer to my trans problem with no luck, so I finally decided to ask:
I have a 2001 Explorer 4dr XLT with a 4.0 SOHC and 5R55E transmission. I recently lost 3rd gear and above as well as reverse. If I pull it down into 1st gear it reacts fine, even performing engine braking, manually engaging 2nd gear also works fine. If I put it in drive it just slips, reverse is also gone with just a little drag at high rpms.
I've been reading about the 3rd/Reverse servo seal leaking as well as the awesome write up on the seperator plate/valve body gasket replacement. Problem is I don't have any experience with transmissions, although I have rebuilt engines.
I've also heard about the servo pin bore repair which may or may not be the source of the problem.
My question: (finally) Based on the description above (and flashing OD light -sorry I haven't pulled the code) are there any insightful guesses about whats going on with it?
I've been told by a reputable shop $1100.00 for the servo pin bore, or $1650 for a used trans (both have 90 day warranty)
I'm on a really tight budget, any help is greatly appreciated,
Thanks for the help, the forum is great!
Old Jul 23, 2008 | 09:37 PM
thelonerangerxlt's Avatar
thelonerangerxlt
I would probably go with the used transmission. Sounds like you have several issues with that one.....
Old Jul 25, 2008 | 05:42 PM
mfp4073's Avatar
mfp4073
without codes you dont really know where you are at or where to go. This could be electronic as easy as a physical problem. You might consider throwing a valve body at it once you get codes pulled and find solenoid problems. You can get them for about $350 with new solenoids and several upgrades from central valve bodies. they also carry a 12 month unlimited mileage warranty.
But all that is jumping the gun until we have some codes to talk about. Remember, a used transmission is going to have all the same failings as the one you already have.
Old Jul 25, 2008 | 06:07 PM
marragtop's Avatar
marragtop
How many miles are on it, and do you know the history of any service done on the trans? I wouldn't do anything until the codes are pulled. Did the trans shop pull them?
Old Jul 25, 2008 | 06:31 PM
mfp4073's Avatar
mfp4073
I would not be surprised if it came back with a solenoid code.
