Sponsored by: Kumho
power steering PSI output
Old Jul 23, 2008 | 11:17 AM
skunktruck's Avatar
skunktruck
Question power steering PSI output
Good Morning,
Does anyone know what the PSI output is for a 79 f250 4x4. I ask because i want to put a Mile Marker winch on the truck and i see that it runs off the pump. The pump requires 1500psi to operate at 10500lbs. So is there any special kit to get?
Thanks
James
Old Jul 24, 2008 | 12:31 PM
Lazy K's Avatar
Lazy K
I don`t know for sure but I think the operating pressure is around 1000psi. I don`t think there would be enough flow for what you want and the stock resevoir would not be big enough.
Old Jul 24, 2008 | 01:09 PM
75F350's Avatar
75F350
The stock pumps were not known for big performance, and the common upgrade for these trucks are the Saginaw conversion. The pressure output is greater, and they can be modified to accomodate more.
Finding brackets from an "E" series vehicle with a similar engine will make this a bolt in deal. Only hose ends will have to be changed, but a hydraulic shop can do this, or make up new lines in a snap, for less money than a complete OEM style line.
Here is a tip: your pump, regardless of which one you install will get the snot worked out of it, and it will get hot. Keep it cool by adding a large cooler. For this winch application, the demands will be very high, and a large cooler will be the difference between survival and failure.
I run a large transmission cooler for my power steering system, because my steering box used to get hot enough to cook eggs while off road.
Consider the upgrade Saginaw box, and be happy from the beginning. Wibch performance , and steering performance will be increased.
TruckerATK
Oct 4, 2016 04:31 PM
ExPACamper
130
Mar 16, 2016 05:57 PM
Pad2383
15
Nov 4, 2012 01:30 AM
eallanboggs
1997 - 2003 F150
25
Dec 2, 2008 06:37 PM
christaylor
Aug 10, 2004 07:21 AM
