Durospark magnetic pickup
Old Nov 24, 2002 | 11:19 AM
Mike W's Avatar
Mike W
I took apart a distributor to fix a hard to rotate shaft. While putting it back together I noticed that the vaccum advance moves the pickup back and forth around the base plate. This flexes the wires and is probably what makes them fail. It would be a good idea to carry a spare.
Old Nov 24, 2002 | 09:26 PM
Franklin2's Avatar
Franklin2
[updated:LAST EDITED ON 24-Nov-02 AT 10:27 PM (EST)]They use a high quality wire with many strands to help prevent this, but you would think eventually they would fail. Knock on wood, never had one fail yet though. It would probably cause a very hard to find bucking or missing on acceleration when the vacuum can moved.
And the old points systems had the same wire (one) running to the coil.
Old Nov 24, 2002 | 09:55 PM
Mil1ion's Avatar
Mil1ion
iontkendall
Dec 21, 2010 04:53 PM
hotfalcoon
Sep 17, 2010 06:06 PM
darrin1999
General Diesel Discussion
Sep 27, 2006 10:45 PM
CrazyFordMan
Dec 4, 2003 09:04 PM
Seifferlein
May 11, 2002 02:22 PM
