Ignition Switch Removal
Old Jul 22, 2008 | 07:47 AM
johnsjsj's Avatar
johnsjsj
Whats The Best Way To Get The Switch Out So I Can Remove The Covers Around The Column To Replace A Broken Turn Signal Switch? Thanks
Old Jul 22, 2008 | 08:04 AM
mueckster's Avatar
mueckster
Turn the key to the run position and push the retaining pin thru the small hole in the bottom cover. Then pull out the key and cylinder. When finished, push it back in and turn to lock.
