It does the same as the Dfuser 18k mod, except it is on all the time. I had a Dfuser and you can definitely tell a difference. It boosts high pressure oil. The Dfuser allows you to adjust the resistance.
i would think if you have a TS or DP..there would be no need to do this mod and most likely not safe to do it..im sure if you call ether of them guy's this mod is done though the tuner...It maybe of some help to the super chip..its just a box to fool the PCM for more fuel...
Couple weeks ago I asked about the Dfuser mod since I had seen one on ebay and thought it might work. Got several responses, some for, most against. Now I'm thinking I might try it, but not sure if the temps really scream up there like some have said. I know most folks here are DP owners, but I'm about 300 shy of getting one. All I need is some aditional power (HP and q and hopefully a little mpg increase).
