adjustable rocker arm swap
Old Jul 20, 2008 | 07:59 PM
gearhed1971's Avatar
gearhed1971
Can rocker shafts from a 390 with a non adjustable hydraulic setup be converted to an adjustable rocker operation just by swapping rocker arms?
Old Jul 21, 2008 | 05:54 PM
FFR428's Avatar
FFR428
Needsmorecoffee.
Yep. Just remove, check, clean and replace. And I'm sure you know you'll need new pushrods for the adjustables. Ball and cup.
Old Jul 21, 2008 | 09:01 PM
gearhed1971
awsome,thanx for the reply.Anything special to look out for?
Old Jul 21, 2008 | 09:28 PM
FFR428's Avatar
FFR428
Needsmorecoffee.
Years of clogged gunk in the old rocker shafts. Any gauling or excessive wear on shafts, stands or rockers. Adjusters on the stock adj rockers should yield a 7ft lb breakaway tq value. Note oil holes in rocker shafts go in the down postion when you assemble. Note proper waver washer install and use new cotter pins in the ends if they are not aftermarket C clip type. Overall a good check up, clean and parts inspection.
